MrWizard's avatar
MrWizard
Moderator
Jun 07, 2015
Adding More Solar Panels
i'm looking at Amazon at the Windy Nation 100w
and the Eco Worthy 100w panel
both are 100w, specs are close 17.4 working volts 5.75 max working amps
versus 17.9 working volts and 5.56 working amps
the price difference is $18 per panel, so it is NOT the deciding factor, quality and performance are my concern
either should be compatible with the uni-solar but the windy nation 17.4v is the closest
i want to purchase (3) panels
replace (3) of my 40w uni-solar with (3) 100w poly panels
i will gain 180w bring my system to 685w total
the Xantrex C-40 can handle it, specs call for a peak of 85 amps and then it goes into current limiting and/or disconnect to prevent damage to controller
started the day with good overnight shore charged batteries
i'm running a solar charge test today and so far peak is 18+ peak amps with an avg of 16.28amps at 13.57v output at controller, with loads running, PC, fans, and fridge cycling
looking to see what max total accumulation is for the day from the existing panels
one panel drivers side far front, has a damaged cell
i have not disconnected it for a diagnostic yet, i'm sure it is a contributing factor, but i'm not sure how much of a factor
i will replace it with one of the good panels that i swap out with the new ones
i'm looking at this partial replacement, because of size & placement and i need too keep some room on the roof for repair access, vents A/C etc..
any experience or comments on the two panels choices , appreciated
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
