road-runner
Nov 29, 2018Explorer III
Two possible factors:
(1)Could it be that the voltage is lower with both devices running together?
(2)With a small generator, running the microwave will result in the waveform changing. More so if it's not an inverter generator. Adding a resistive load results in lessening the waveform corruption. Can see this only with a scope. Measuring each device individually while both are running might yield a small clue or two.
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 28, 2026
