Gdetrailer
Nov 29, 2018Explorer III
MrWizard is spot on.
AC "electronics" and DC "electronics" ARE two different creatures when it comes to mathematical computations..
To fully understand and make the math work can often lead to the use of Calculus.. You cannot simply add and subtract to make the numbers work in AC voltages due to Inductance, capacitance and resistance that your AC loads WILL present.
The cleanliness and accuracy of the generator WAVEFORM also plays a key roll in just how accurate your "Killowatt" meter will end up.. Poor quality sine waves OR Modified Sine waves do not "play well" with the Killowatt meter..
Additionally, you ARE using an instrument to measure AC that I suspect is NOT very highly "calibrated" and trying to use it as the source of "truth".
The "Kilowatt" meter is effectively like trying to use a sledge hammer and a railroad spike to to fix a Rolex watch, just not enough FINE DETAIL and most likely a lot of ERROR to work with..
Rather than spinning your wheels, sometimes you just have to "accept" that the results may be less than what you want due to variables like how accurate your meter is, how accurate the gen waveforms are and how reactive your loads are..
Nearly 30+ yrs of electronic tech experience talking..
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 28, 2026
