wa8yxm
Nov 30, 2018Explorer III
You are correct in that having the resistive load on there screws up the power factor.
What is power factor
Well if you use the proper hardware you can plot a voltage curve and a current curve (In fact I have done this in a lab) and then you can measure the angle between the two. COSINE. adding the resistive load reduded the angle. and thus increased the cosine. (Power factor = Cosine cosine zero (No difference totally in phase) = 1)
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 28, 2026
