Gdetrailer
Nov 30, 2018Explorer III
BFL13 wrote:
I am not pretending to be in a Lab. It would be interesting to see all this on a scope, but I don't need to for what I am trying to find out. (And did thanks to the help from everybody on here for what to look for)
IMO the Kill-A-Watt is doing a good job for me, where I am seeing consistent results even if those results are not calibrated exactly.
EG, see the three sets of results in the thread about converter loading during Bulk. The "internal consistency" is clear.
I found it to be useful to have the Kill-A-Watt at the generator end and the Trimetric on the battery end to get the input numbers to go with the output numbers. Doesn't matter if they are not perfectly accurate in absolute terms. Just consistent and "close enough"
BUT, you ARE attempting to do "lab work" and get "lab results" in order to figure out as to why your setup is not working as expected.
You may be getting "consistent results" but are they when you end up with a discrepancy that you are not able to answer or explain?
I am basically trying to get you to understand that in the world of AC it is often difficult to get totally 100% results with zero discrepancies and it IS OK to accept and move on as long as you get good enough results..
This may mean instead of getting your wanted 75A charging into the batteries with your current gen and settle for say 70A or 72A instead.. The time difference between 75A and say 70A is not going to be the end of the world and take what, an extra 10-15 minutes of charging time?
It IS about "compromising", you took a chance on a 2200W inverter gen, it isn't performing quite up to spec with your converter and you are trying to figure out why it doesn't with a $25 meter..
Just not sure what you expected.
The gen, the meter and/or your converter all could be at fault or one or two of the items may be at fault, you may never know unless you eliminate at least two of these variables.
Your efforts are valiant but the results will continue to fall short unless you remove/eliminate as many of the variables as possible..
I guess I am having difficulty understanding the fascination with the 2200W inverter gen, personally I dumped my old 2000W old school gen and use my 4000W old school gen. The 2000W gen was barely able to handle a PD9160 with Charge Wizard..
I suspect the HF 3500 Inverter gen would be able to power right through that 75A converter load and never break a sweat..
I don't think the 2200W inverter gen you have has quite enough headroom to deal with the non linear load it is giving the generator..
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 28, 2026
