brulaz wrote:
Google tells me that a battery can be treated as a simple resistor with respect to voltage drop. And so can all the wires and connectors. Apparently then Ohm's law applies.
Example:
A single 12V battery with 50A load (600W) has Vd voltage drop
Two 12V batteries in parallel, with 100A load (50A each, 1200W total), also has Vd voltage drop. Half the internal resistance but twice the current so Vd remains the same.
Two 12V batteries in series, with 50A load (@ 24V, 1200W total), has 2xVd voltage drop? Twice the internal resistance of a single battery but the same 50A current, so TWICE the voltage drop.
But, percentage-wise the Voltage drop of two batteries in parallel is the same as two in series. And the wattage (VA) drops is the same.
No idea if this happens in practice though.
I'm gonna try my way hehe
All for a same load 1200w (I didn't like you changed that hehe)
My 12v Crown as a R=0.0091ohm
Single @12v=100a X0.0091ohm=0.91Vd
parallel 1/2 resistance 0.0091/2=0.00455ohm
@12v=100a X0.00455=0.455Vd
Series X2 ressistance 0.0091X2=0.0182ohm
@24v=50a X0,0182=0.91Vd
It would seem as far as internal resistance it's better 12v parralel ??
I'm getting something a bit different... :h
What am I missing ?
EDITI see now, like you said pourcantage wise.
@12v 0.455Vd/12vX100= 3.8%
@24v 0.91Vd/24vX100= 3.8%
got it
Edit #2But parallel had more than twice of amp hours. 1+1=2.7 :)
Check this video
https://www.youtube.com/watch?v=snaJxB_psg8
