shootandfish1's avatar
Oct 04, 2014
AGM Battery Discussion-Discharge/Charge Cycles
OK, Let us agree to no FLA vs AGM is better comments. AGM ONLY!!! And this discussion is aimed mainly for my fishing boat (still an RV-Right!!!), but applicable to any DC deep cycle purpose. And this group of 'Experts' are the most technical bunch of folks known;)
I'm researching batteries for the more powerful trolling motors, 80-112 lb thrust, 24-36 volt. Boat desperately needs more weight as far forward towards the bow as I can practically place 2-3 12 volts. Since this is where most of the 'pounding' takes place (both on the water and towing), I feel that AGM's are better suited than FLA Batteries for this purpose.
I was (still am) looking strongly at the Sam's Club Duracell AGM Gr 31, which is the same as Deka's (East Penn) AGM Gr 31, 105 Ah@20Hr rate, 69 Lb. My research indicates that the SC Duracell is very good choice for the price and equally important is that a Sam's Club is located in about every town near my intended fishing and camping trips (SE USA, mainly Florida).
East Penn has a wonderful pdf discussing the care of AGM and Gel Batteries. On p 10 is a chart showing that a Deka AGM should be good for 370 cycles for a 50% DOD and 200 cycles for a 80% DOD. (Gel Batteries have much better numbers, but I fear difficulty in obtaining 'fresh' batteries at a reasonable cost and SC stocks the AGM Gr 31 should I need a replacement.
After various on-line searches, I came across Cabelas 900-X AGM made by NorthStar, also available in a Gr 31, 101 Ah@20Hr rate, 76 Lb. NorthStar is stating that their AGM is good for 900 cycles @ 50% DOD and 400 cycles @ 80% DOD!!!!
Is NorthStar's advertised cycles for stated DOD's reasonable? I understand that correct charging is necessary for a battery to perform, but over double the cycles at 50% DOD and double at 80% DOD is quite a strong statement for 2 almost equally (by weight) batteries.
The Northstar's Gr. 31 is about twice the cost of the SC Duracell, so the cost per Ah and cycle are actally quite close. $179 compared to $385ish. Taxes and shipping costs yet to be factored in.
Did not mean to be so 'long-winded', but curious to what the 'Pro's' here think. Hope and pray that my links work.
Fred
Deka Tech Manual For AGM & Gel Batteries
Deka Marine/RV AGM
Sam's Club-Duracell AGM Deep Cycle Marine/RV Gr31
NorthStar Marine/RV AGM Gr 31
Cabelas 900-X AGM Gr 31
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 07, 2025
