SoundGuy
Aug 14, 2016Explorer
Rbertalotto wrote:
Does humidity have any effect on the starting requirements of an AC unit?
Temperature. As one who has owned two EU2000i gensets and powered 13.5K A/Cs your results are exactly what I would expect ... as outside ambient temperature rises so too does compressor head pressure, causing it to draw even more power. With your EMS in the circuit and gensets running at ECO speed low voltage threshold is causing the EMS to disconnect power to the trailer, remove it and the A/C compressor starts even though long term damage may result from repeated excessive low voltage sag each time the compressor attempts to ramp up to speed. Your solution is to use both gensets paralled together in order to avoid excessive low voltage sag and to remove the EMS when running on the gensets.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
