ktmrfs
Aug 17, 2016Explorer III
smkettner wrote:
Use the PI bypass mode. You will not encounter low voltage with Honda generators. The Honda will shut down.
depends, even in the bypass mode you need enough voltage to keep the PI line voltage relay energized. In eco mode, even with 2 generators running if your at higher altitude and high temps, the generator will drop down enough before it kicks out for the PI relay to drop out BEFORE the generator kicks out, then the generator voltage goes up, relay kicks in, voltage drops....... get the picture, you'll hear the relay chattering and the AC won't start.
I and others have been there with the PI. get the AC started not in eco mode is the solution.
