- Luke_PorterExplorerI have found out a torsion "square" axle can be aligned (bent). I had it done at a truck shop. I have been there before with trailers with "tube" axles.
- marbil_146Explorer
Luke Porter wrote:
Looks like I bent my torsion axle and it's eating tires. Can it be aligned?
I had my Alko-kober axles done two years ago at an alignment shop in my area that specializes in RV axles and it has been fine ever since.
They bend the entire axle using the aligning equipment to get a proper setting. - Chris_BryantExplorer III disagree- I know at least some can be aligned- my Airstream shop manual has instructions, but it takes a special machine to bend the axles.
- eHoeflerExplorer IISadly, no. If you bent a torsion axle, you bent the spindle, and the spindles are not replaceable.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
