Last_Train's avatar
Last_Train
Am I Supposed to See 12V at the Tail Lights?
Re our Coachmen Freedom Express 192RBS:
I have a verified measurement of only 10.39V at my left rear tail light. I am producing 13.9V from my 7-pin connector on our Ridgeline at the tail light terminals. I've measured this under various conditions (connected to truck with and without the engine running; connected and disconnected from our 30 amp shore power).
My wife even noticed that our right tail light seems less bright than the left (measured something over 9V at the right tail light!). A couple of months ago I do recall having to replace our left bulb . . . seemed a little premature for a rig less than two full years old.
Eventual goal: tap in to good 12V DC to keep a rear view camera charged up while in transit. Seems like this wouldn't be advisable with this kind of power available at those lights. But this also seems to point to a larger problem.
Thoughts, anyone?
  • Find a place you can make a solid ground for this issue and in the future. I promise you it will be helpful. Build a jumper wire long enough to reach throughout the RV. Now, as suggested, use the same ground because an invalid ground reference will make you crazy and misdiagnose things.
    Make sure you used the correct bulb and that it is inserted correctly. I have seen wrong bulbs stuffed into sockets.
  • As rjxj says, use the same ground point when checking both lights to make sure the difference is in the positive side and not your ground reference point.
    If there is still a difference then you may have a bad wire connection or an undersized wire.
  • Ground? Where are you checking voltage? Across the pins or to a known good ground?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
