surgtech56's avatar
surgtech56
AmeriLite 23BW water tank fix replacement
Has anyone replaced their water tank on a 2011 AmeriLite 23BW. ? We have a leak around the valves picket that goes into the tank.
How do I post a photograph?
  • mobeewan wrote:
    Is the leak between the fitting and tank or the threads where the drain valve screws into the tank?
    Is the fitting cracked and leaking from the threads?
    It looks like both. I thought it was just from the threads but it looks like it’s also leaking between the fitting and the tank. I was going to put a hose clamp on the threads .
  • Is the leak between the fitting and tank or the threads where the drain valve screws into the tank?
  • Sorry blurry, it’s been raining. There’s. A leak around this outlet. Any adhesive that will hold s a quick fix? Thank you
  • google rv.net photo posting: just follow Barneys instructions.
    Jerry
  • You might give a little better description of the leak. Is it the actual water tank leaking, or maybe just a hose fitting, from the water inlet? A picture would help, if you can see where the leak is.
    Jerry
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 13, 2025
