- Old-BiscuitExplorer III
2oldman wrote:
Old-Biscuit wrote:
I wouldn't say it 'lasted' considering its condition. :) My coach is 18 and I think I've had maybe 3 of these rods, and this is the worst one.
I am REALLY surprised that Magnesium Rod lasted 6 years.Need to bottle that water !!
The water for the first 3 years has been split between WA (soft) and CA (hard). Last 3 years has been mostly hard, NM and CA.
YES it has LASTED
What you have is typical of an anode rod that has been doing it's job....being sacrifical so STEEL tank is protected
Still 30% Plus of life LEFT in your rod but good time to replace it
- 2oldmanExplorer II
The water for the first 3 years has been split between WA (soft) and CA (hard). Last 3 years has been mostly hard, NM and CA. - Old-BiscuitExplorer III
2oldman wrote:
Old rod has a tit on it. It's mag.
I have gone 'dyslexic' since my surgiers/hospital stays
I have things backwards.....even get letters reversed when typing ....ugh!
Suburban OEM Magnesium DOES have the Tit and the Aluminum one has a smooth flat head
Need to bottle that water !! - 2oldmanExplorer IIOld rod has a tit on it. It's mag.
- MFLNomad IIAgree with Old-Biscuit...6 years use, likely aluminum rod, or darn good water!
I also would not use anything but the Suburban rods. I flush my heater out twice a year, check the rod, which may last as much as two seasons, but I always get at least a years use with the mag rod.
Jerry - Old-BiscuitExplorer III
Lynnmor wrote:
The life on an anode rod depends on the water being used.
I looked at the RV anode rods on eBay and the "tit" theory did not hold.
Suburban OEM Magnesium #232767
Suburban Optional Aluminum #232768
Many aftermarket rods are mislabeled and inferior - LynnmorExplorer IIThe life on an anode rod depends on the water being used.
I looked at the RV anode rods on eBay and the "tit" theory did not hold. - Old-BiscuitExplorer III
2oldman wrote:
MFL wrote:
6 years.
The reason I was asking how long the anode in picture has been in heater.
6 years...doubt it is a Magnesium Rod.
Aluminum lasts LONGER but doesn't provide as much 'protection' because it doesn't dissolve as quickly as Magnesium
Dissolving/being sacrifical is what provides the protection
Check the end of hex head....got a 'tit' in center then it's aluminum - 2oldmanExplorer II
MFL wrote:
6 years.
The reason I was asking how long the anode in picture has been in heater. - Old-BiscuitExplorer IIIOEM is Magnesium...for better overall tank protection
Magnesium rod has FLAT hex head
Aluminum rod has 'tit' on hex head
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 11, 2026
