path1's avatar
path1
Any tricks, strange noise under hood/ which pulley?
Need help finding out which pulley or bearing is on its way of going out on 5.4 ford engine. Beginning to make a small grinding noise and would rather fix now in driveway instead of on the road. Problem is I can't figure out where the noise is coming from.
I've loosened the belt and wiggled each pulley, no excessive play in any of them.
I've put a screw driver again each pulley, no vibration feeling up screw driver.
Any other ideas I could use to figure this out?
2003 5.4 I'm pretty sure the pulleys are:
Alt, pulley tensioner, water pump, A/C, etc
  • I'd take the belt off and individually spin the pulleys. The culprit should be obvious. I would lean toward any idler or tensioning pulleys as being the problem.
  • Very carefully use a Stethoscope, it will pick up sound very well from each pully. The grinding noise could also be a water pump, alternator, power steering, etc. Does the noise change when you turn on the AC? could be the idler pulley.
  • My guess would be the serpentine belt tensioner. Mine was noisy so when I changed belts, I changed the tensioner. They are only a few bucks.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
