path1's avatar
path1
Any tricks, strange noise under hood/ which pulley?
Need help finding out which pulley or bearing is on its way of going out on 5.4 ford engine. Beginning to make a small grinding noise and would rather fix now in driveway instead of on the road. Problem is I can't figure out where the noise is coming from.
I've loosened the belt and wiggled each pulley, no excessive play in any of them.
I've put a screw driver again each pulley, no vibration feeling up screw driver.
Any other ideas I could use to figure this out?
2003 5.4 I'm pretty sure the pulleys are:
Alt, pulley tensioner, water pump, A/C, etc
