joeshmoe
Jul 14, 2017Explorer
Anyone Recharged Their A/C Refrigerant?
I have a Coleman Mach 11K unit that has been blowing warmer and warmer for about a year now. The **** thing is only 3 years old with VERY little use. Can't be expected to buy a new one already, right?
It finally quit blowing cold this weekend. Went on top to check all the normal stuff. Caps tested good. Compressor is clearly working hard as it gets super hot with no condensation accumulating anywhere. Low side is no where near being cool. So....
I snooped around online and found out you can repair these things even though they're marketed as "unserviceable". I bought a Supco bullet service port to install inline on the low side, BUT I first need to find the leak and determine how bad it is and whether dumping in refrigerant/sealant/oil will do the trick. Problem is, where do I find this R410a? It isn't exactly like you go to Walmart and pick some up. Where would I find it without paying a fortune?
