Baja_Man's avatar
Baja_Man
Are Ground Bonding Plugs required for Each Inverter/Genny?
I am installing a new Progressive Industries hard wired EMS (EMS-HW30C).
I want to use a ground-neutral bonding plug on inverters/gennys to avoid using my by-pass function.
I plan on using my two Champion 2500W Dual Fuel inverters combined, using the Champion 30AMP ParaLINK Parallel kit.
Will each inverter/genny need its own plug or will one plug on one them suffice?
Thanks!
  • wnjj's avatar
    wnjj
    Explorer II
    BFL13 wrote:
    Baja Man wrote:
    BFL13 wrote:
    OP is asking about plugging into gens, but the two receptacles are in the paraLink.
    The neutral-grounding plugs I am referring to are plugged into the inverters 120V receptacle
    I have seen the bonded 15a adapters used for that and you would have one on the shore power cord plug. You say you will be using the parallel kit, so you will be plugging into one of the two 30a paraLink receptacles depending on your plug type, not into one of the gens.
    Do you intend to have a 30a adapter modified to be bonded? Very confusing.
    He’s planning to plug the RV into the paraLink kit but the bonding plug into one of the 120V receptacles on one of the generators.
    The answer is it will work fine so long as the ground wire (I.e. the screw loop terminal) from the paraLink is connected to the ground lug on the generator with the bonding plug.
    All bonding does is connect the green ground wire to the neutral. Once all neutrals are connected to each other and all grounds are connected to each other bonding can be done on either generator or at the unused the paraLink receptacle.
  • When I parallel my Hondas it only takes 1 (one) bonding plug. Either generator and your EMS will see a common ground.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    Thanks!
    if it is like the honda, nope, only 1 plug needed. the parallel operation truely parallels the 120V outputs.
  • OP is asking about plugging into gens, but the two receptacles are in the paraLink.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
