OregonTravelers's avatar
Feb 29, 2016
Atwood 8500-IV furnace problem
Need a little help. We have a 2005 National Sea Breeze LX with an Atwood Hydro Flame 8500-IV series furnace. The furnace has been causing us problems for some time and hoping someone can offer some help in finding the problem.
When the furnace is turned on, the fan runs and then a short time later the furnace fires and begins to heat. The furnace works fine and heats to the temperature set on the thermostat. Now comes the issue.
Once the selected temperature is reached, the furnace shuts off and the fan continues to run for a short while. Just like it is supposed to. Then as soon as the fan shuts down, the entire furnace start sequence starts over again. The fan starts, the furnace fires and begins to heat. After a few seconds, the furnace shuts down and the fan continues to run for a short while and then shuts down. Then the entire process starts over again. Fan, furnace on, furnace off, fan, shut down. The sequence happens a few times and then the 12 volt circuit breaker trips. If I let the room cool enough that the room temperature is below that set on the thermostat the and reset the circuit breaker the furnace will run thru the heat press fine until the set temperature is reached then the start and stop sequence begins all over again until the circuit breaker again fails.
1. The sail switch has been replaced.
2. The propane pressure has been checked.
3. Heat ducts checked, cleaned and moved to remove possible restrictions.
4. Air return checked and cleaned.
5. The control circuit board has been replaced
6. The connections on the 12 volt circuit breaker has been re-soldered.
I would appreciated any suggestions on what may be causing the furnace to recycle problem and what I can do to fix the issue.
Thank you
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
