climb_on's avatar
climb_on
Atwood 8531-IV DCLP Furnace Not Working
I brought my camper to my, upper Michigan, hunting camp in early October, used the furnace all weekend and everything was fine. I returned a couple weeks later on a cold Friday night and the furnace would not come on. No fan. No spark. No ignition. Just a "click" up on the relay board. The next day the troubleshooting started and I failed to get it to work. I checked the fuse in the panel, replaced the board on the furnace itself. I just hauled it back home to Minnesota where I can troubleshoot it more effectively. I don't "think" it's the thermostat, but I will try putting the original manual thermostat back in. Years ago, I had upgraded the thermostat with a digital hunter thermostat conversion, using a process that I found posted on a forum somewhere. Many people did it successfully as I did as well.
When I set the thermostat, to call for heat, I hear a click, up in the relay board inside the AC enclosure, but the furnace will not start. I suspect the click is a relay engaging or trying to engage. I don't see the relay board available for sale anywhere.
I did a little trouble shooting with a service guy from the local RV place, in Escanaba, MI and we were pretty sure it was the board in the furnace. $170 part, installed, no change. Ouch.
My fear is that mice have chewed a wire(s) up in the ceiling. I can tell there was some mouse activity up there. No chewed wires that I can see, but I could hear one (or more) up there when I pulled it out of storage this summer. I can't see any relationship to the wires in the AC wiring harness to the wires entering the furnace to be able to check for continuity.
Looking for ideas on what else to try?
I attached a few pics...First 2 are the furnace model & furnace board, next 2 are the relay board, and the last is the wire harness from the relay board.
  • enblethen wrote:
    Go to the furnace, locate the two blue wires. Connect them together. This should start the furnace fan, within short period 10-20 seconds the furnace should produce heat.
    If nothing happens verify 12 volts DC to furnace. No power, probably fuse.
    Power but no fan check small circuit breaker mounted on fan housing.
    Fan comes on but no heat, blow the furnace out, paying attention to the sail switch area.
    I will go try that now. I do believe I got the blower fan to turn on when I was troubleshooting it back in October. Don't recall how, but I bet it was the 2 blue wires. Where is the sail switch located? I know what a sail switch is, but I've never noticed one.
    A strange development I forgot to mention....on the evening after replacing the board on the furnace (with no change), in the middle of the night the furnace fan turned on. No spark or gas though. I looked at the thermostat and I still had it set to call for heat. After waiting to see if the heat would come on (it didn't), I clicked the thermostat off and the next day, I could not recreate the fan coming on.
  • Go to the furnace, locate the two blue wires. Connect them together. This should start the furnace fan, within short period 10-20 seconds the furnace should produce heat.
