HiTech
May 27, 2013Explorer
gwtriker wrote:
With everything 12V turned OFF, something in my RV was draining the house battery ... after much testing, determined it was the Atwood water heater(GC6AA-10E). With heaters' 15A fuse pulled - no drain: fuse in - drain. At the heater proper, pulled 12V connector to heater - no drain. With connector still disconnected, tested voltage on the connector - with switches in off position no voltage / voltage when in on position.
Any ideas as to what is causing the drain when the 12V connector is plugged into the heater????
Do you by chance have a 12v heating element? Is it on? Is your hot water hot when you have a full battery? 15a is way more than a controller board parasitic load. Either I am totally missing something or you have a 12v heating element active, though 15 a seems small for an element.
Jim
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
