Paul1944's avatar
Paul1944
Atwood water heater won't stay on.
Just bought a barely used 2017 Shasta Oasis camper, hope I didn't buy somebody else's problems. Anyway, the Atwood water heater will not keep running after it kicks on, it stays on for only about a minute or so then it shuts off for 10-15 minutes before it kicks back on again. When I look in from outside there is nothing that I can see that would cause this such as spider webs or wasps nests. I did notice that when I first turn on the switch inside the camper the "DCI-FLT" light comes on. Any ideas or suggestions?
  • "Model is GC6A-8E
    Flame is more orange than blue.
    There is a wire with what looks like a resistor in it, what is that for?"
    8E has separate controls for electric & gas
    ELECTRIC:
    120VAC comes from a Circuit Breaker to on/off switch (backside of WH Tank) then thru set of T-stats to element (also backside of WH Tank)
    GAS:
    12VDC comes from Fused source to 'thermal cut out' (fuse in clear tubing----it blows at 190*F if flame blowback occurs and stops ALL DC to water heater. One shot device --replace if bad)
    From thermal fuse DC goes to/thru TT-stat then to circuit board
    Circuit Board then sends DC to ECO/Gas Valve AND spark electrode
    Posted earlier
    When flame lights off......is flame BLUE and quiet (very slight roar)?
    IF NO (YOU stated more ORANGE then Blue)
    Might need to adjust air shutter ---typically only needs to be roughly 1/4 open
    Might need to clean orifice (soak in alcohol/air dry), clean burner tube (small bottle brush)
  • Old-Biscuit wrote:
    RED Fault Light is triggered when flame fails to light and PROVE it lit
    Flame Rectification ---milliamp signal generated
    Spark electrode provides high voltage spark for ignition AND is return path for that milliamp signal
    *Electrode must be CLEAN---soot/carbon removed using emery cloth
    *High Voltage wire connection at transformer on circuit board clean/tight
    *High Voltage wire not loose in the ceramic insulator
    *Ceramic Insulator --no cracks--milliamp signal will go to ground and circuit board won't receive it
    *electrode must be engulfed in flame
    *spark gap 1/8" - 3/16"
    Model is GC6A-8E
    Model is GC6A-8E
    There is a little wire with what looks like a resistor in it, what is that for?
    IF NO
    Is this a GAS Only Water Heater OR GAS/Electric Combo?
    Gas only vs Combo use different wiring systems
    So what is MODEL?
  • trailrider wrote:
    The obvious question is: "Is the water heater full of water?"
    Yes.
  • How can I reply to a specific response? I would like to answer Old-Biscuit questions directly.
  • Model is GC6A-8E
    I found a mud dobbers nest in the flame tube, cleaned it out as best I could, thought my problem was solved but WH only ran 5 minutes before shutting back down.
  • Could be something as simple as corroded connections turn off water heater and remove and reinstall each connection after putting some dielectric compound on each one.
  • RED Fault Light is triggered when flame fails to light and PROVE it lit
    IF NO
    So what is MODEL?
  • Could be thermostat or ECO going open. Use an Ohm meter immediately after shut down check for continuity.
    Could be the probe for the ignitor/flame sensor is not in the flame. It should be red hot.
    Possible that the flame tube has restrictions. Remove and clean good.
