dougrainer
Jun 15, 2018Nomad
The most common problem for your type problem is a defective motor. It has a dead spot in the windings. Troubleshooting takes 30 seconds. Open and close the entry door. If the AMBER step light comes on and off when you open and close the door, the step module and wiring are OK. When it fails, you have someone open and close the door and you tap on the motor with a hammer. IF the step motor then operates the motor is bad. Always do your testing with the engine running. The extra 1 to 2 volts from the engine helps activate a bad motor. Doug
Related Content
- Feb 01, 2026Community Alumni
