SJ-Chris
Jun 15, 2018Explorer II
dougrainer wrote:
The most common problem for your type problem is a defective motor. It has a dead spot in the windings. Troubleshooting takes 30 seconds. Open and close the entry door. If the AMBER step light comes on and off when you open and close the door, the step module and wiring are OK. When it fails, you have someone open and close the door and you tap on the motor with a hammer. IF the step motor then operates the motor is bad. Always do your testing with the engine running. The extra 1 to 2 volts from the engine helps activate a bad motor. Doug
Great advice all!
Okay, I checked and the step light seemed to be functioning properly (coming on when the door opens). But the step wasn't moving. Thinking I would have to bring it in to the RV mechanic/shop, I decided "okay...let's give it a couple taps with a hammer". I couldn't imagine that I'd be so lucky to have that fix the problem (....afterall, it seems like something a caveman would do! lol....). Well, after a few taps I tried opening the door and low-and-behold....the step started working again!
Can anyone explain what is so magical about a couple of love taps on the motor? (....I've got a technical background and it just doesn't seem like a sensible approach, yet it worked!).
A couple of you have indicated that since the hammer tap seemed to "fix" the problem that it is likely a bad motor. Now that it seems to be working, I'm not particularly motivated to bring it in to the shop. What should I expect will happen with this step/motor? From your experience, does it seem likely that it will **** out again very soon? Or have some of you performed this "tap magic" and then had a trouble-free step for years to come?? Just curious...
Thanks!!! This forum is incredibly helpful!
-Chris
Related Content
- Feb 01, 2026Community Alumni
