Farmboy666
Jul 01, 2018Explorer
beemerphile1 wrote:dougrainer wrote:beemerphile1 wrote:
FWIW, I replaced the fabric on my 18' awning last year without removing the end caps or messing with the springs.
Can't be done. I don't know what you did or how you did it, but Dometic awnings require at least one end cap to come off. The nylon insert ropes fold inside the tube and the end caps fit OVER them. Now, if you DRILLED out the end caps to get the old fabric removed and install the new fabric, that is NOT how you do it. Doug
Absolutely correct, drilled and slotted the end cap and then added additional rivets on each side of the new slot.
So apparently it CAN be done!!!
