cannesdo's avatar
cannesdo
Awning replacement fabric adventure...oy
Ok, I read up, I watched the videos. I was ready to go. Cotter pin, right end -- annnnnnd....*go*!
Yeah...
Realized I had a different design so the cotter pin needed to go in sideways -- ok, no problem. Right before starting I realized the youtube video I was watching had a sister video by the same people for manual dometic/AE awnings. Perfect. This one told me to put the pin in the left side of the awning. (I suspect that larger awnings (or is it manual awnings) have two springs. Can anyone confirm that? Ok, yes that's right, they do) Oh...Ok. Got the pin in there just fine. Went to pull up on the ends the roll it down and the spring mechanism -- on the RIGHT -- violently unspools itself. I know...I'm lucky I didn't get hurt. I was holding it by the tube and when I lifted it out it unwound. The video I watched (https://www.youtube.com/watch?v=vnxDLPDoVCc&t=302s) said to pin only the left spring, then *roll it down*, then release the tension from the right spring but the right spring unspooled itself the second I lifted the top casting out of the holder. I could have really been hurt. (It's *possible* that I had it set on the "roll down" setting rather than the "roll up" setting.)
So I rolled it down, removed it. Cleaned all the parts, put the metal guard on the new awning fabric. But I need to know how many tension turns are needed for an 18' A&E 9000 awning. Found it -- 12 full rotations for the 9000. If anyone needs this rotations for different lengths chart for future reference: page 6 http://www.rvrepairmanual.com/manuals/awning_replacement_instructions.pdf
So tomorrow I need to keep the pin in the left spring, rehang it, replace the bracket, replace the tube, replace the rivets, retension the right side with it set in the "roll down" setting (is that what holds the tension tight?) pulling toward me, then roll the awning back up and replace it in it's holder on both ends. Bolt them back in then remove the pin on the left side. Yes? :/
I answered most of my own questions but the links here are really helpful for anyone doing the job in the future...
  • 4x4van's avatar
    4x4van
    Explorer III
    Anyone know where to purchase the metal guard/wrap? My last RV had the metal guard and after 12 years the material was still in perfect shape. My current one (without the metal guard) is already showing signs of wear after just a few years.
  • Imo the Acrylic fabric is the best, lighter weight doest crack, brighter colors, I've had acrylic and vynIL , I'll choose acrylic every time
  • I pulled out the awning about a foot from retracted, taped the ratchet lever so it could not get bumped, removed the upper bracket from the front so the fabric could be slid out/in the channel on the side of the trailer. Removed the lock screw that holds it in the channel, took the arms loose at the bottom and walked the fabric out of the channel, then we laid the awning arms on sawhorses, with the bottom of the arms resting on the ground, and unwrapped the fabric from the roller. Marked the roller for what went where, and fed the new one into the roller (end cap was manufactured with a notch for the fabric to pass thru, and the valance was pushed into the groove and we drilled a hole in the end cap and pushed the plastic into the groove on top of the valance. When that was done, we wrapped the fabric around the roller, leaving about the same amount hanging off the roller and then we walked the new fabric in the channel on the trailer, carrying the arms vertical like we had removed it. Snapped the arms in the lower brackets, reinstalled the upper front bracket with lots of sealer, removed the tape and pulled the awning out and then in several times to seat it. ran a screw back into the channel to hold the fabric in place and done. Never touched the springs.
    A&E 8500
    Charles
  • We need to do our carefree, I have awning patch tape on it now, which is working OK. Any comments on the new shiny plastic fabric vs the traditional fabric?
  • I also had the awning fabric replaced and by a profession. I viewed all the videos on utube and figured it could not be that difficult. Well, they took 1&1/2hours to remove and install. I watched and the videos didn't even come close to what they did. It was well worth the extra money to have them do it
  • You make me glad I had it done. :) Seems like $150 well spent.
    Glad it's working out though.
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 18, 2025
