QCMan
Sep 25, 2021Nomad III
Retired JSO wrote:
With awning open, push up on roller tube to relieve pressure and slide awning along roller tube to align. Not at the top since it is screwed into place.
Yes this! On our MiniLite this was what was causing the same problem you have. Not wanting to put a screw through the awning I fished around a big box store and found plastic rod that just fit in the slot the awning goes in, cut it so it was hitting the awning and even with the end of the slot and ran a short screw into the piece near each end. Problem solved!
