Carole_Burgess's avatar
Aug 28, 2021
Awning working backwards after fabric replacement
Hi,
Sorry if this is posted in the wrong spot...just replaced fabric on 17' Faulkner awning, put 14 turns counterclockwise on front spring, same clockwise on rear and the tension is exactly backwards. I tried winding them both the other way but same result. Can someone tell me where I've gone wrong?
Thanks,
Seann & Carole
  • The front spring/cap has the lock (back in it's original place), all marks made before removal are lined up. It's like we're pulling from the wrong side of the tube. It's a mystery.
  • How old are the torsion springs? Is it possible you removed both Torsion and installed the front on the back and the back on the front? Doug
  • The awning material is wound correctly...over the top of roller, the "backwards" is that the tension is reversed. You have to force the tube to roll up, and it is spring loaded while coming down, exactly opposite to what it should be. I have even tried tensioning the springs backwards, but it's the same result.
  • Explain working Backwards. ALL RV awnings (even a more than 35 year old Faulkner) the Arms are wound by turning the arm or spring Counterclockwise on the RH. and CLOCKWISE on the Left hand. Does the awning roll up to store but fabric is backwards???? Doug
    Look at this video. Granted it is an Electric awning but I want to know if you have the same problem with the fabric reversed or backwards.
    https://support.lci1.com/correcting-awning-fabric-which-rolled-up-backwards
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Jan 18, 2025
