adkfreeridex's avatar
adkfreeridex
bad battery, system wont work on 120AC
Hey Guys and Gals,
Im relatively new to my trailer (18 foot fleetwood pegasus 2007), and I believe that my battery is beyond salvage. However when Im plugged in to 120AC I still dont have interior lights, pump, etc. I know that the 120AC goes to the power converter to run interior 12V accessories, but will a bad battery keep the system from running on 120? I hope so, otherwise I have bigger problems than a $100 battery.
Thanks!!
  • Our rig works just fine with the battery turned off and running 12v things through the converter while on shore power. Not sure if a bad battery would keep a converter from operating properly.
  • DrewE's avatar
    DrewE
    Explorer III
    Some converters don't operate properly without a battery. It's very reasonable to assume that a bad battery could also cause improper operation or non-operation, depending on the battery fault.
    Connecting most any known good 12V lead acid battery in temporarily would let you check the converter using a voltmeter. Even something as simple as connecting the trailer electrical system to the truck battery with jumper cables (carefully) should be sufficient to verify the converter output voltage.
  • If the battery has an internal short it could cause the converter to trip constantly. I'd remove the battery negative cable, rest the converter and see if it powers up. If so, the battery is the problem.
  • The first thought is that the converter is bad. But that is after all connections have been checked.
    If the converter is bad....or bad connection, could that make you think the battery is bad, when really it is the converter not charging ??
    If you had a simple thing like a voltmeter, all your questions would be answered
  • If the battery is removed, it may be that the converter was disconnected as it first attached to the battery. Or, it could be that the converter needs to see something close to turn on at all.
    If you come back with a converter model, someone might know.
    Matt
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 18, 2026
