HadEnough
Jan 23, 2021Explorer
Basic Question About AC Power Wiring
How are RVs usually wired up?
I have a standard arctic fox RV and I’m having trouble with the AC portion of the wiring.
Symptoms:
*After running an air conditioner for 4-5 hours, off an external generator connected to the shore power cable, I get a brownout” situation and the microwave turns on and off every second or two repeatedly during this brownout.
*Its getting worse. Sometimes I get the same thing on startup. Other times it randomly works great for hours and hours.
*when I use the onboard generator, it will either work great or it will have the same type of problem as the external. HOWEVER, when the external generator would have the brownout or cycling, the onboard generator is smarter and just shuts down.
*there seemed to be a VERY long delay tonight using the onboard generator before the power came on.
So far I’ve looked at the transfer switch. I opened it. Hard to see the contacts, but they didn’t really seem to do anything actually probably because I was on the shore power generator. And it was working fine.
So my question is related to diagnosis.
What components are involved?
What components are common to the shore power and the onboard generator such that they can cause brownouts, cycling on/off of power and the onboard generator to decide to shut down?
I’m looking hard at the automatic transfer switch but I don’t see any problem.
It seemed to get better a bit when I exercised the main breaker on the panel, but it’s intermittent and that may not even be it.
What components are there to check?
Symptoms:
