BFL13
Mar 28, 2020Explorer II
Not with those, but note the AGM requirement to get them full every so often (often as possible), which means charging at 14.4ish volts constant ( with no dropping to 13.6v before you get there like some converters will) to 0.5 amps per 100AH of battery. Now you can go to 13.6v.
So how are you going to observe that? I can see the amps taper down to that with my Trimetric monitor. Point being that going AGM also means getting an ammeter you can monitor.
You also need a charger that will hold the voltage at the right level until amps are down to spec.
