RJsfishin's avatar
RJsfishin
Battery Cable Crimpers
I got into what I thought would be "simple" battery maintainence yesterday, only to find a hidden corroded mess ! Most all the crimped lugs are a solid mass of corrosion up inside the lugs, and all covered up w/ wire loom taped at the ends.
I'll need to replace the 2 parallel connecting cables, not a problem.
But 2 of the 3 main cables need the lugs replaced also, always a problem, w/o a genuine battery cable crimpers. So I am going to invest in a good crimper of some kind.
Anyone here done this ?? And can you recommend any piticular one that won't break the bank. I'm seeing mechanical, and hydraulic units that come in 8, 10, 16 ton units, such as this one,....
http://www.ebay.com/itm/10-Ton-Hydraulic-Wire-Battery-Cable-Lug-Terminal-Crimper-Crimping-Tool-9-Dies-/380780092529?pt=LH_DefaultDomain_0&hash=item58a8431c71
It looks like I'm working w/ 1 to 1/0 sizes. Any ideas from experience ?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
