Ron_Nielson
Feb 15, 2014Explorer
BFL
As I understand your last post, if you have a BIG BATTERY, heavily discharged, that is when the converter will push the highest amps to the battery if the wiring supports that much amperage. If you have a small battery, lightly discharged, small wiring, that will produce a less than max amp push to the battery.
Is this correct?
Is this correct?
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
