BFL13
Feb 15, 2014Explorer II
Instead of thinking the converter pushes think of the battery as pulling. The battery will "accept" a certain number of amps, where at any SOC, it will accept more amps if you raise the voltage. (That is why they use 14.4 instead of 13.6 so it will accept more amps)
At any chosen voltage, the battery will stop accepting that many amps when it gets to a certain SOC, so after that if voltage is held the same, amps must taper as "acceptance rate" declines as SOC continues to rise.
You can see it all here in my famous fantastic ugly graph, which I built after reading up on this stuff in Barre's book:
http://www.bestconverter.com/Books_c_67.html
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
