I've read about the possibility of overcharging a battery. I occasionally connect my trailer to shore power for extended periods of time and am wondering if it's possible to over charge the battery.
A fixed voltage charger is fine in cold to mild summer temps, but in hot weather will over charge batteries. If you do much dry camping on a generator, you will want a 3 stage charger for faster, safer charging. And you can leave it plugged in all the time.
I assume you have a Magnetek/Parallax converter. These are OEM on most RVs. They are single stage chargers that apply 13.8v to the battery. 13.8v is a compromise, to low for fast charging, to high for maintaining a fully charged battery. They are notorious for boiling the water away in the battery. Keep a close watch on the water level in the battery.
For long term storage I use a Battery Minder. It keeps the battery charged with little maintenance required.
I also replaced my Parallax converter with a Progressive Dynamics 3 stage converter that charges the battery fast, then reduces the voltage for maintaining the charge.
I have left my TT plugged in for the past 3 years at home (except when travelling/camping of course), you have to keep up with the water in the battery.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
