sign_man's avatar
sign_man
battery charging
When charging (2) 12volt rv batteries through the on board converter/charger, would two honda eu2000's work any better than just using one genny to charge?
  • My Honda 2000i handles an IOTA-55 converter just fine even at the full 55A output (depleted batteries.)
  • If your one generator is really struggling and loud, then that means your charger is too big for one. In your case I doubt that's happening.
    The short answer is no.
  • If all you are doing on ac power is charging the battery, then I'd say one 2000va generator would be plenty even if you have a 100w converter. if you are running the air conditioning and the microwave at the same time, well then ...
    Depends on what you have for an "on board converter/charger" ... whatchagot? :h
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
