Moffittclan's avatar
Moffittclan
Battery disconnect or isolation solenoid? HELP!
I think I might have a bad isolation solenoid because my house batteries aren't charging with the engine running...I tested by measuring volts on house batteries with engine off (12.1) and then with engine running (12.1). I pulled this from behind the green circuit board in the fuse center under the driver side, front of coach...but now I'm not sure if it's the battery disconnect or the solenoid...
As you can see in this next picture, there is a button on the board that says to push it and listen for a click to test the aux start (I'm assuming this is talking about the solenoid??) but when I push it, I don't hear anything. I don't see anything else in this compartment that looks like a solenoid...
We are leaving on a long trip in a few days, so I need help quickly! Thanks in advance!
  • The solenoid in the picture is the disconnect solenoid and has little (nothing) to do with charging off the engine.
    That bottom picture references a service manual- try to find it.
  • Artum Snowbird wrote:
    Before you get anything new in parts, make sure your ground return is good. Connect from the negative on the house battery to the negative on the coach battery with a jumper cable and just make sure that part is OK. A loose negative will prevent anything from charging.
    With just the negatives connected, start the engine and then see what the voltage is at the house battery.
    They charge on gen and shore...so I think that side of things is good...
  • Before you get anything new in parts, make sure your ground return is good. Connect from the negative on the house battery to the negative on the coach battery with a jumper cable and just make sure that part is OK. A loose negative will prevent anything from charging.
  • Gjac wrote:
    In your picture you can see 2 large nuts and two small nuts, there should be 12+v across the two large nuts if it is working
    Unfortunate wording.
    You should see 12V ON both lugs if it is working. (Exactly the same voltage.)
    Seeing 12 V ACROSS the two lugs means something quite different.
  • Also, I've read you can get one from autozone...how do I know the right part number that is compatible?
  • Gjac wrote:
    In your picture you can see 2 large nuts and two small nuts, there should be 12+v across the two large nuts if it is working if only 12+v on one lug it is not engaging. Also check the voltage on the small nuts one should have a 12 v input to the solenoid. You can always jumper the 2 large connection to use the MH for your trip until you get a new solenoid.
    Is this the right part to replace if my house batteries are NOT charging from the alternator and if I don't hear any click when I push the battery boost button on the dash of the coach?
  • Gjac's avatar
    Gjac
    Explorer III
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
