Moffittclan's avatar
Moffittclan
Battery disconnect or isolation solenoid? HELP!
I think I might have a bad isolation solenoid because my house batteries aren't charging with the engine running...I tested by measuring volts on house batteries with engine off (12.1) and then with engine running (12.1). I pulled this from behind the green circuit board in the fuse center under the driver side, front of coach...but now I'm not sure if it's the battery disconnect or the solenoid...
As you can see in this next picture, there is a button on the board that says to push it and listen for a click to test the aux start (I'm assuming this is talking about the solenoid??) but when I push it, I don't hear anything. I don't see anything else in this compartment that looks like a solenoid...
We are leaving on a long trip in a few days, so I need help quickly! Thanks in advance!
Having RV issues? Connect with others who have been in your shoes.24,329 PostsLatest Activity: Oct 28, 2025
