Ski_Pro_3
Dec 08, 2017Explorer
It is common practice that when you disconnect a battery for any reason, you disconnect the negative lead first, then the positive. Your situation shouldn't be any different. Disconnect the negative first, even if you are not going to disconnect the positive.
The reason negative is disconnected is because the electricity flows from negative to positive.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
