Vintage465
Nov 16, 2019Nomad
Battery Monitors
I've nearly completed my upgrade to my Solar System(Pics coming when I'm done). Thinking(after the fact of course)that I should have considered a Battery Monitor in the upgrade, or at least preparations for such an install.
I know very little about battery monitors except that most experienced boon dockers with solar recommend them. I don't see any reason to try and take a low rent route to get this done and end up with an iffy unit that works her and there or not at all.
I hear the Morning Star unit is kind of the standard. I also hear some pretty good things about Victron.
So:
1. I assume a shunt needs to be installed some where on the positive near the battery bank. I am "Parroting" this term "shunt" , as I really don't know what the term "Shunt" means. I've seen the pic's of one and it looks pretty straight forward to install. Is the shunt the only thing that needs to be installed for the monitor to gather info? How would I size the shunt? We only use 12v. No inverters. The only high draw item we have is the furnace. How close or far from the batteries is acceptable to install the shunt. Should it be very easily accessible? Meaning, is there a reason to view it regularly?
2. I have Samlex PWM 30a controller, will a Victron or Morning Star work with that controller? I looked in some installation info and reading material and that info doesn't seem be very forthwith as of course they are hoping one uses their charge controller.
3. In order to have Bluetooth connectability for monitoring does there have to be a "base unit hardwired somewhere that the iPhone can snag the signal?
Is that what I'd be doing by installing a shunt with the wiring going to the hard wired battery monitor?
4. Maybe there is a good link to send me to that has "battery monitors 101"?
Thanks!
So:
Thanks!
