Tiger02
Jul 10, 2017Explorer
jesseannie wrote:
I work at Lowes part-time in the tool dept. and if you are going to use it for wheel lug nuts I would consider the new Kobalt 24 volt impact wrench. BUT you need the highest amp battery in the lineup you may have to buy it separately but it is worth it.
This is a powerful tool.
Jesseannie
This is what I have, and use it regularly. Very powerful breaking torque for removing stubborn bolts, and makes removing wheels a breeze. I do use it to tighten lug nuts, but just a single squeeze that gets the nuts to around 80 ft/lbs then I tighten with a torque wrench to spec.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 02, 2026
