azrving wrote:
Use a hydrometer to check the specific gravity.
allen8106 wrote:
This is the correct and only accurate way.
SoundGuy wrote:
So how would you "experts" propose doing this with sealed AGMs? :S
Hint - load testing, which works with all types of batteries. ;)
azrving wrote:
This expert read that the op said he had Trojan 105. The problem with yanking out a battery and running to a auto parts store is that if the battery is simply discharged they will tell you that the battery is no good. You can't load test a dead battery. Pay closer attention.
Oh I'm paying attention alright, Mr "Expert" ;) ... and the
fact remains that the
"only accurate way" of determining the condition of battery is
not measuring it's SG with a hydrometer - which is impossible with a sealed AGM, GEL, LITHIUM, etc, anyway :S - load testing which can be used on
all types of batteries is. :B
