BFL13
Aug 31, 2019Explorer II
bpounds wrote:
It's a probe, not a ring terminal. I'm not really inclined to change it.
I think I might change the gorilla tape to some aluminized duct tape. The stuff actually meant for ducts, not the gray stuff. I think that might insulate it a bit from the ambient.
Incidentally, my inside monitor does display the probe temp. It's in C°, but at least you get it.
It is just a rough instrument to tell the charger what to do with its charging voltage wrt to battery temp. If the batteries are outside in the cold and the charger is inside where it is warm, it will do a better job by having that probe out where the batts are.
Some folks fuss over "battery temp" which rises while being charged above ambient temp. If you are adjusting voltage wrt ambient, you might be over-voltage when the internal battery temp warms up.
IMO ignore that. It will drive you insane since you can't measure all that like in a lab, while out camping. Like time2roll says, don't get too far into the weeds with temp comp in mild ambients.
EG, if the batts want 14.8v at 25C, then that is the same as 15.2v at 5C. Assumes your charger can adjust its voltage accordingly.
A curiosity is how the TempAssure of a modern type Parallax converter is set to 60F as the "nominal" instead of 77F like the battery specs have it.
Solar controllers can be with on-controller temp adjust, or by remote to the battery temp sensors. Not much point to on- controller if the controller is inside and the batts outside.
Whatever your situation is, just having the sensor "with" the batts to pick up their ambient wherever they are, is "good enough for government work."
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
