Rbertalotto's avatar
Rbertalotto
BE CAREFUL with your 120V side of things
I have a 1998 Palomino Bronco Truck Camper. I decided to exchange the Centurion 3000 power converter for a Progressive Dynamics 4700 series unit.
The installation went great and all the 12V and 120V outlets worked great.
But looking at the GFI outlets throughout the camper, and they being old and a bit crusty, I decided to change them out for new units.
I shut off the main breaker in the PD panel and started to remove the old receptacles. Wowza! Gave my self a heck of an electrical shock! Using a meter I found the white/ neutral wire was hot and I had 120V from white to ground!
I went back to the PD panel to be sure I didn't have a senior moment and hooked up the white and black backwards. Everything looked great.
Outside I looked at the AC plug on the end of the electrical service feed and realized that it was a replacement plug. Took it apart and sure enough, some idiot , previous owner had wired the plug backwards! The cable was a 10/3 and the #10 wire would not fit under the connection in the "Harbor Freight" sourced plug.
I'm surprised the GFI outlets didn't trigger? And I'm so thankful that no one got hurt or shocked in the couple years I've owned this camper.
Rather than replace the plug with another one, I bought a 25' 12/3 extension cord and removed the female end and wired it into the PD panel. Now I have a nice molded, weather-tight molded plug and all is well with the electrical system.
Be safe out there!
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 17, 2025
