- pkunkExplorer
MEXICOWANDERER wrote:
Now THIS is a heavy-duty lug. Others are pretenders!
http://www.delcity.net/store/Heavy!Duty-Die-Cast-Copper-Crimp-Lugs/p_1013
I like that! - MEXICOWANDERERExplorerNow THIS is a heavy-duty lug. Others are pretenders!
http://www.delcity.net/store/Heavy!Duty-Die-Cast-Copper-Crimp-Lugs/p_1013 - harold1946ExplorerI installed mine with stainless steel bolts, washers, nuts and lock washers.
- MEXICOWANDERERExplorerLifeline uses a berrylium copper post and bolt. Mine has turned orangish I suspect from oxidatio.. I will brush it bright and coat it.
- Vulcan_RiderExplorer
pkunk wrote:
Thanks all, for the affirmations.
So what IS the FL1 terminal....please ?? - pkunkExplorerThanks all, for the affirmations.
landyacht318 wrote:
I did not know what a Fl1 terminal was.
And I STILL don't. ?????
You have AGM batteries. The likelyhood of corrosion is MUCH less than with conventional types so just being sure the contact surfaces are perfectly clean should be enough. An appropriately sized star washer can give a little extra piece of mind. - Chris_BryantExplorer IIThat's how I did it:
- landyacht318ExplorerI did not know what a Fl1 terminal was.
+1 on the thick walled ring terminal held tight with bolt and lockwasher.
Make sure the hole diameter on the lug is no wider than on the FL1 terminal.
http://www.genuinedealz.com/heavy-duty-cable-lug-tinned-copper-1-awg-or-2-awg-gauge-stud-size-5-16-inch
Perhaps one could go a step further and acquire silicon bronze bolt nut and washer.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
