BFL13
Jan 10, 2014Explorer II
fpresto wrote:
If you are talking about the seals they are accessed from the inside with the slide partly retracted and talcum powder works great. Baby powder is just talcum powder with a scent added. If you are talking about the wipers on the outside then silicone or 303 works well. Many people confuse the seals which seal out air and water with the wipers which clean the slide when it retracts.
So what keeps it sealed when the slide is in?
I tried silicone on the wipers outside and all it did was make a black mess on the white fibreglass ends of the slide. Took a while to get that cleaned up.
I find the inside foam whatever seals on the slide and the trailer itself stick together after the slide has been out a while, and are hard to break apart on starting to bring the slide in, but never have any trouble getting the slide to go out.
It has to work hardest at the beginning of coming in where it has to come up over the hump at the outside edge of the main floor. Going out and then down is easy.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
