mike740ski's avatar
mike740ski
Slideout will not extend
Looks like this will be the year of the gremlins. Out camping now this week. The remote slide out wont work. The RF panel lights are not active. Neither the blue or red lights will activate when I hit tha wake up button. Looked into manual method and two issues with that: The crank handle hits truck so that is useless. Second problem was the tip of the long socket mechanism used for cranking the slide is broken and And just spins. I Attempted to go with half turns of the crank when realized nothing was happening.
Tried powering down the whole camper and then back up. Did not work. Since the slide out is on top of the cabover step, I cannot inspect the fuses. Not sure where any if or where any breakers for the slide out might be. All other electrical is working.
My logic, make sense?:
Reviewing the electrical schematic right now. If its not the motor, could be 40a breaker, thermo limited circuit breaker, or 20 a act fuse. Since no power to activation switch, that eliminates thermo cb. I assume 40 a breaker also feeds other appliances? That would eliminate 40a breaker then, leaving 20 amp act fuse, which I can't get at since the slide out is currently on top of the cabover step.
Something happened Friday nite between the time I retracted the slide to head out, and the time we pulled into camp 4 hrs later and tried to extend it.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
