Bumpyroad
Dec 05, 2020Explorer
RedRollingRoadblock wrote:
Installed a Luxe Neo https://luxebidet.com/product/neo-120-bidet-attachment/ at home as well as in MH. No water heater or air dryer. It is what the DW wanted. I was skeptical about it but am fine with it.
She chose this model so I didn't need to run electrical. Since it uses cold water it can be an eyeopener at times, especially at the temps cool off in the MH. Works okay on the pump, has cut the TP usage way down. I installed on a Doemetic 520 with no modification. Had to buy a fitting at the hardware store for a few dollars. I needed to replace the bowel seals so I did it while I had the throne on the workbench.
Found them on Amazon.
I can't quite figure out how that works. I "assume" a water hose fits that one fitting but see no "spray" device.??????
bumpy
