beemerphile1
Feb 14, 2021Explorer
Let me guess, this is in an outside compartment where the power cord is located? There is a metal breaker box, a separate fuse block, and an Iota converter screwed to the wall?
You have a shorted circuit somewhere between the fuse block and the panel inside. It could be anywhere in between. Has any work been done on it lately?
Instead of blowing an endless number of fuses, use an incandescent light bulb in its place. The bulb will light and you can go about locating the short. When the bulb goes out - the short is gone.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
