He should be seeing around 25 amps with flat panels at high noon with 470w.
Yes it is Voc that is used for the controller input limit, and that is adjusted for temperature so in cold weather the panel voltage might be higher than rated Voc, so need some "margin"
The Bluesky has some other self -limiting amps thing can't remember right now. It is in its manual we looked at before sometime.
He could put the two 140s in series with the Bluesky and get a second controller (Eco-worthy 20a MPPT ?)for the single 190 and parallel the controllers.
Trick is to have both controllers with adjustable settings so they can be set to the same voltage to add their amps better.
