dmussell56's avatar
dmussell56
Both blinkers flash for right and left
On my Flagstaff T12rb when I turn on either the right or left turn signal, both right and left flash. It has a 7 pin connector as does my truck. I tested the truck to make sure that side sends iut the correct signal for right and left and it does.
When I look at the wires coming from the trailer harness there are only six wires running to the trailer. I can see the yellow wire (left turn) was cut off and is not connected to the trailer.
Is there anyway this ever worked without that wire being connected.
BTW, it was this way when I drove it off of the lot in 2021.
If they refuse to fix it under warranty is it as simple as connecting a wire to the yellow and run it back to the left rear light? Not that getting at the back light will be easy.
  • I don’t see any possible way it could have ever worked correctly if the left turn signal wire is not connected to the truck.
    Did you check the wire colors at the taillights? I can’t imagine someone only ran one wire and jumpered the two lights. But then ????? I would certainly try to get the dealer to fix it under warranty. I am guessing no one checked the lights before pulling off the lot.
  • Do your other lights come on? Do they all blink? I'd bet you simply have a bad ground connection.
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
